Barry Posted March 8, 2020 Report Share Posted March 8, 2020 Selling a jeep to buy 2 land rovers. Out of the frying pan and into the fire. 1 8 Link to comment Share on other sites More sharing options...
Kalahari Posted March 8, 2020 Report Share Posted March 8, 2020 make sense - you need one for parts (or to carry the emergency supply of oil) 15 minutes ago, desertdude said: But I did sell it for almost twice what I paid for it Note to self: Never buy used car from desertdude! 8 Link to comment Share on other sites More sharing options...
sertac Posted March 8, 2020 Report Share Posted March 8, 2020 First change the coolant, put new radiator cap and add 2 extra fan. If it wont solve it add also aluminum radiator. Than it should be bullet proof. Another reason to like Grand Cherokee is the huge radiator it has originally. I am never overheating. I just change the radiator with the brand new original one, i put toyota coolant and new radiator cap. On the highway it stays little over quarter and in desert if i push it only it will reach half. 2 1 Link to comment Share on other sites More sharing options...
Gaurav Posted March 8, 2020 Report Share Posted March 8, 2020 I hope I am not late to this party. Boiling is a sign of coolant leak somewhere as DD mentioned. Get that checked first from where it's leaking and get that fixed. Please do not spend even 1 dhs on educated guesswork, because in overheating there are so many things involved that everyone here is right in there own way, but there own way may not be the same as your current problem. So you might spend all the money in mods and still face the same issue. If after leakage stops, it still overheats then get your radiator viscose clutch fan checked if its working when car is overheating or not. If your radiator fan is still running on normal speed (not on full speed) while car was overheating in the desert, that means viscose clutch fan need a replacement (500-800 Dhs) or you can run a direct clutch to make that run at high speed all the time. (50 Dhs). This is totally acceptable mod in GCC heat for off-road cars. Second step, get a switch install to start AC electric fan without AC running, because original AC fan is huge and ideally make a lot of difference when car is overheating in the desert. (50 Dhs). If these two brings good result: Option 1: Live with it and switch off AC whenever car overheats. Option 2: Install 2 more fans and run them on demand with AC. If AC fan and direct clutch fan wont help, then: Upgrade to slightly bigger radiator, preferably copper+ aluminium core Change the thermostat Change the coolant 4 1 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
Gaurav Posted March 8, 2020 Report Share Posted March 8, 2020 30 minutes ago, sertac said: First change the coolant, put new radiator cap and add 2 extra fan. If it wont solve it add also aluminum radiator. Than it should be bullet proof. Even if radiator is leaking...? Even if viscose clutch fan is working at half speed...? 2 1 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
sertac Posted March 8, 2020 Report Share Posted March 8, 2020 11 minutes ago, Gaurav said: Even if radiator is leaking...? Even if viscose clutch fan is working at half speed...? Of course if anything is broken it need to be change first. I am considering the case everything is in good condition and still overheating. 1 1 Link to comment Share on other sites More sharing options...
Wrangeld Posted March 8, 2020 Author Report Share Posted March 8, 2020 (edited) Thanks guys. So I understand it like this: 1. New radiotor cap 2. Refill with red coolant 3. Install a back up/second fan (for when the above don't work) 4. If this all fails, buy a Nissan. Simple. Thanks See you soon in the sand. Edited March 8, 2020 by Wrangeld 1 3 1 Link to comment Share on other sites More sharing options...
Srikumar Posted March 8, 2020 Report Share Posted March 8, 2020 30 minutes ago, Wrangeld said: 4. If this all fails, but a Nissan. Not Nissan. You need to buy Land Cruiser or RR. Anything else is blasphemy. 3 Link to comment Share on other sites More sharing options...
Gaurav Posted March 8, 2020 Report Share Posted March 8, 2020 4 minutes ago, Srikumar said: Not Nissan. You need to buy Land Cruiser or RR. Anything else is blasphemy. And it should be tested in Liwa by Japanese Engineer, right....? 3 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
Srikumar Posted March 8, 2020 Report Share Posted March 8, 2020 36 minutes ago, Gaurav said: And it should be tested in Liwa by Japanese Engineer, right....? Absolutely 🤣 2 Link to comment Share on other sites More sharing options...
