COVID19 Compliant - Sunday Evening Short Newbie Desert Drive - Fossil Rock - Sharjah - 4 Apr 2021
Chaitanya D
This drive is organized in full compliance with the COVID19 guidelines. We expect every member that joins this drive to go through below information and and strictly follow these guidelines in order not to jeopardize someone's health, and to ensure we can keep organizing these drives safely.
MUST READ AND TOTALLY AGREE: COVID19 Precautions
MUST READ AND TOTALLY AGREE: BAN POST
Two Way Radio Guidelines
  • Every Offroader brings his own radio, programmed to the frequencies described in below advice topic.
  • We will not share spare radios or program your radio on the drive. If you need assistance in programming the radio, post a topic on the Carnity website with your questions and we will help you out.
  • No radio = No drive. It is an essential tool and you should make sure you bring it on every drive and learn/practice how to use it.
MUST WATCH: NEWBIE VIDEO BRIEFING
Drive Details
Level:  Newbie and Above (All Levels)
When:  4th Apr 2021, Sunday
Meeting time: 3.45PM(SHARP - Without any exceptions)
Meeting Point: Mahafiz Tree Shade - https://goo.gl/maps/Tj9WXKFDYB43KpWZ9
What to bring along: Loads of water, snacks (for yourself), smiles, face mask, rubber gloves, enthusiasm, willingness to learn and your own compressor for tyre inflation.
Approximate finish time: 7PM
End Point: As Far as we go
LIMITED SPOTS AVAILABLE:
  • Limited to 10 cars only. RSVP will close 12 hrs before the drive
PLEASE RSVP ON THE BELOW CALENDAR EVENT
  • WOW (+2) 1
Dear friends,  thank you for signing up on this drive
Mandatory gear required for this drive - shovel, flag, programmed radio, deflator and compressor.
This area is very bushy with some tight dunes and soft patches at places. We will be heading towards fossil rock for a beautiful sunset and venture towards Khatim or east of fossil rock. There will be enough time and terrain to test your finesse along with doing climbs and sideys.
Make sure your car low lying parts are removed (air dam and plastic parts especially for cars with low ground clearance ) , else you risk breaking them and bumpers for sure 🤣.Drives are always with a disclaimer that I/we are not certified mechanics to sort all issues if any which can happen on sands, will try to help to the best of our knowledge and abilities.
Please ensure Covid appropriate behavior on the entire drive. Deflate to 15 psi for regular tires and 12 psi for all terrain tires
See you on Sunday
