Ren13
Fortuner suspension mods
Good morning guys I own a 2012 model Toyota fortuner thought of increasing the body height so that going off roading gets easier can you suggest what's the right way of    doing it.
There are small suspension shops scattered all around sharjah industrial area where you can get your vehicle raised just go to then and explain how much raised you want that way they will install harder springs so that will hold the car higher...
It is a cheapest way, but make sure you do not raise the car more than 2 inches as when you increase the ride height you are playing with the center of gravity. Proper way would be to get a proper lift kit with springs and suspensions which suit the off-road, the springs should be stiff to give you better travel. Besides lift kit it would also be advisable to increase the size of your tire, but make sure you will not have any rubbing issues, plus get proper off-road tires like the Yokohama Geolander ATS.
I would second with Rahimdad advise than Shadow79, just because you need a specialize masters degree in dealing with those small suspension shops in sharjah, as 99% of the time they will sell you something lemon proving that you are a moron.
If you want a proper job, find what fits best on your model of fortuner and change the all 4 sides with proper upgraded version. Check with known brands like: Ranchos, Tough dog, Rough country, Old man EMU, Kings, etc.
These proper upgrade might cost you more but be rest assure that you will not topple or get broken suspension in desert when you needed them most. I fixed broken suspension once in desert  and spend 4-5 hours in heat and later realize that owner has got one of those used suspension from shj shops and it was misfit as per vehicle weight and that's why it broke in second minor jump.
Make sure you get a proper 4 wheel 3D alignment done afterwards. A guy came to me a while back after getting a lift done at a monkey shop, complained that the car was unstable. The problems was massive positive camber like in the picture below. A lot of these people are good at swapping parts but when it comes to setting up, adjustments, anything technical, they haven't got a clue.
thank you guys i guess will try to save up on buying a proper lift kit designated for my car model and get it installed, will probably look at a 2inch lift kit so that i can drive on and off road with ease.
@Ren13 Don't think that it will be expensive to get a lift kit and put it off. At an Iranian shop they will charge you approximately AED 700 - 800 for the stiffer springs. They also have a habit of telling you the bearings are gone, the bushes need replacing and scaring you till you end up spending around AED 2000. A proper suspension kit from a proper workshop will not cost you more than AED 2500 with the peace of mind. looking forward to the updates regarding your ride.
Hi Ren 13 ,
I just want you to know something I have done to my Xterra : Installed a levelling kit costing about AED 500 then ended up having to spend a little more on adjustable camber bolts . As Barry had suggested please have the front and rear aligned ( if the rear are alignable ) if you increase the height you will move the CG( Centre of Gravity ) up hence there is a need to have wheel spacers . One of the desert fox suggested 1 inch out for every 2 inch up . Go out for a couple of drives offroad see if it meets your requirement the n stick with if you feel that you need better suspension then please buy new springs and shocks that will give you lift and better suspension ( Initially going for total suspension change might throw you off as the ride will be stiffer and will be very noticeable on-road ). Please make sure you have adequate under chassis protection like bash plates , if your Fortuner has additional body kit please remove them as they will be removed by Desert !
  Just my 02 Fils !
 Some of the most important tools and kit to be carried during your off-road trips have been mentioned by our Master Desertfox  Rahimdad in the following post :
Drive /Ride  Safe!
Slick72
  • Similar Content
    • By Drift1
      HI Every One, im new here, to dig up an old topic, Ive got a set of Fox 2.0 im fitting to a 2008 fortuner as our desert work horse vehicle.. I think i will need some lift blocks for the rear coils as the front coil-overs are height adjustable.. - Could anyone be more specific on a shajah workshop that might be able to help out - name - address would be great
    • By Automax Group
      2019 Toyota Tundra Crewmax SR5 # 5.7L # V8 # 0 km
      *PRICE INCLUDING VAT*
      Specifications:
      i force V8
      6 speed Automatic Transmission w/sequential shift
      4WD part-time 4WD w/electrical controlled
      TOW/HAUL mode eng and Tran’s oil cooler
      Heavy duty batt, 4&7 pin connector
      Power assisted 4 wheel disc brakes
      18 “TRD wheels
      Vehicle stability control, Traction control
      ABS w/electronic brake force distribution
      Brake assist & smart stop technology
      Rear backup camera & Parking sensor
      Manual headlamp level control
      Trailer sway control
      Cruise control
      Power tilt/slide moon roof w/sliding shade
      6 way power adjust driver seat
      7” Hi Res touch Screen / Bluetooth / usb
      HD radio/12 speakers/AUX/CD/SXM
    • By Muhammad Ibrahim
      We provide special pricing for all Carnity members.
      We are the market leaders in American used cars.
      We import and export American used cars and provide to the end user with full registration, passing and ready to drive.
      Come for the comfortable and best service.
    • By Recall
      ANNOUNCEMENT
      Special Service Campaign Statement: Toyota Corolla and Toyota Yaris -Airbag Inflator, Model Years 2012-2008
      United Arab Emirates, Dubai, 5th December 2016: Al-Futtaim Motors, exclusive distributor of Toyota in the UAE, released the following statement:
      "In coordination with the UAE Ministry of Economy — Department of Consumer Protection, and in line with the directives of the Ministry of Economy, Al-Futtaim Motors announces a special service campaign for the Toyota Corolla and ToyotaYaris, model years 2008 — 2012, which will begin immediately."
      "Following communication with Toyota Motor Corporation, we have started a campaign for 40,551 units of the Toyota Corolla and ToyotaYaris model years 2008 - 2012 in the UAE.
      The involved vehicles are equipped with Takata produced front driver and passenger airbag inflators which contain propellants that could degrade after prolonged exposure to high humidity and temperatures. These propellants could cause the inflators to rupture and the airbag to deploy abnormally in the event of an accident.
      In the interests of delivering the highest standards of Toyota quality and customer care, Al-Futtaim Motors has begun contacting customers with affected models to inform them about the situation and arrange service bookings accordingly.
      For further clarification, customers may contact the
      Al-Futtaim Motors Customer Care Centre on 800-Toyota (800 869682) from 8.00am - 700pm, Saturday to Thursday.
      We regret any inconvenience this may cause and thank our customers for their patience and understanding."
      Hotline No: 600 522 225
