How do I turn off the alarm when I pull the ABS fuse?
Hi all,
does anyone know how to turn off the alarm -beeps on a Pajero, when you pull out the ABS-fuse (useful when offroading)?
Also, interestingly (or maybe I’m doing it wrong): the ABS warning light doesn’t go on when I pull the fuse; just brake-alarm light that also indicates the parking brake being engaged.
2 hours ago, skumar83 said:
@hossein did a trial of installing a kill switch an it's mentioned in the below post on the last page. You can check with him if it worked on the last weekend desert drive.
Dear @skumar83 actually not, I researched a lot and it's little risky , the best way is to remove ABS fuse and it's worked fine
I’m driving a 2013 3.5L v6 Pajero.
That switch-idea looks great; going to give that a try, as soon as I fix the repeating-alarm-that-goes-off-when-ai-pull-the-ABS-fuse-problem :-)
Is there any danger in pulling every fuse one by one btw, just to see what gets deactivated? I wouldn’t drive it; just look at the dashboard alerts.
There is an alarm when you remove the ABS fuse?
