Desert Champions Trophy - 2021
  • 3 weeks later...
  • Replies 21
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
While offroading, we cross dunes by using different methods, based on how the dune is formed and what the drive level is. Once you have spent some time in the desert, you will slowly start to pay more
@Frederic Impressive article indeed👍...
@Frederic awesome post!
Posted Images
Superb article with so much useful information...Maybe i'm asking too much but if possible on future drives can you highlight the dune type... for Newbies like me it would be WoW moment :)
  • Totally Agree (+2) 2
  • 4 weeks later...
5 minutes ago, John Vanderbleek said:
Great information here. I recommend this be a class during one of the Newbie Drives.
Perhaps already on the schedule but this would give a better appreciation and understanding of route selection.
Thanks @John Vanderbleek ! I have just made some minor adjustments to the wind direction. After speaking to a friend who works for Skydive Dubai, he explained me the land breeze and sea breeze concept which we are facing here in the UAE:
  • Well Done (+2) 2
  • 2 weeks later...
20 minutes ago, imranaasghar81 said:
Hi Frederic,
what app can you recommend for an iPad / apple to track and log drives providing distance covered etc along with the route ?
thank you
imran
Hey @imranaasghar81check out this topic posted by Fred on the Gaia app
  • 3 weeks later...
  • 2 weeks later...
Didn't want to start a new discussion topic on this, and this seems like a good place to drop it in. If you're out and about this afternoon in Dubai, there's a pretty heavy sand storm that at some points reduced my visibility to 50m.
My question though is - is there a concept of "fresh powder" with dunes just like there is with snow-covered mountains. Having spent some part of my life in extremely cold climates, I would look at snowstorms as the perfect opportunity to head out to the slopes the morning after to find some "fresh powder".
Does the similar concept apply in the dunes?
Or does it make driving more treacherous with more pockets of soft sand after?
Subscribe and then join Offroad Club
And enjoy multiple level off-road drives - every weekend.
  • Similar Content
    • By Zed
      This video is dedicated to the 7 Camaraderie of Bu Tais @Farouq Owdeh @Taufique Surve @Hasan Wahlan @Karthikeyan Govindarajan @xavier @Mus_hus78. Remember what HeadMaster @Asif Hussain says: Follow the track 😂😂😂
    • By Zed
      Thanks to @Hasan Wahlan, I found the trick to getting LandCruiser to climb up with power & ease is to shift it manually to L (in 4-High of course). Unfortunately I was too excited with this discovery and fear of getting stuck on the crest triangle made me step on the pedal a bit too much 😂
      So my LandCruiser flew, as soon as it touched down @Srikumar bhai asked me to check the radiator. Radiator was ok and we continued... Two days later "clicking" noise started coming from the front-driver side, as seen from this video:
      Can you guess what the culprit is?
      If you say CV Boot close enough, it did start with the CV Boot leak, but eventually I had to replace the whole front-left axle 😂  No need to buy new one though, new OEM will cost 2000dhs++ , since i may break it again *touch wood, a good second-hand that costs 400dhs is enough for now 😄
    • By Gaurav
      Driving off-road is very interesting and entertaining experience but there are few basic things you need to check first before heading for your first off-road drive with Carnity Off-road Club.
      Every driver should know when to join for an offroad drive and when to pass until all below things are checked.
      VEHICLE
      Ground clearance: Minimum 8-12 inches under front and rear bumper is must. If your vehicle has 8 inches then you should be careful while driving and slow down while descent and approach to avoid any minor bumper damage. If your 4x4 have EAS (electronic suspension), lift it to the max height and then measure it. Also read the manual to know what is the max speed you can drive with off-road height, as many manufacturer limit up to 60 Kmph with off-road height, which is plenty in most cases. Knowing that limit is better in case you go above that speed, so you can lift it again once you slow down.
        Tow hook: Your 4x4 should have at least 1 tow hook in the front and 1 tow hook at the back, more the better. Also you should check the integrity of all tow hooks and its appearance, if they are shaking or rusted or missing a bolt, then get them fix before joining any off-road drive.
        Engine: Your 4x4 engine should be in perfect working condition without any check engine light or any warning lights on dashboard or leaking oil or coolant. Engine takes more stress while offroading so well serviced 4x4 performs better on off-road. If you recently bought the car and have no idea of last service, then its highly advisable to get the engine service before your first off-road drive.
        Gear / Transmission: Your 4x4 should have LO and High gearing option. AWD or SUV without LO/HI gearing option, generally not advisable for sand off-roading. If you have extensive offroading experience to tackle such vehicles then discuss it on the forum with the trip leader and see if they can allow such exception.
        Suspension: Your 4x4 vehicle suspension should be in reasonable and drivable condition. You can drive with stock suspension perfectly fine and then you can decide to modify it, if really needed. Any suspension lifted up to 5-6 inches are accepted, anything above 5-6 inches lift need trip leader approval before joining any drive to make sure if you have widened the wheelbase to lower the center of gravity in an orderly manner.
        Tires: Your 4x4 tires should be in good condition with enough tread and more than half life left. Tires nearing their end usually fail while offroading, so check for date of manufacturing shouldn't be more than 3 years. No visible cuts or lost tread chunks or cracking sidewall should be there.
        Fuel Tank: You should always join the off-road drive with full fuel tank, as all vehicle consume double or triple the amount of fuel while off-roading. You don't need to change the fuel type from special to super for off-road purpose, continue with your fuel type as per manufacturers recommendation.
        Sign up: Once you have checked all these above points then RSVP the drive calendar and post an introductory message on the drive post - sharing your 4x4 details, previous off-road experience (if any), so that trip lead can acknowledge and plan the drive accordingly.
      OFF-ROAD GEAR
      You don't need any off-road gear or recovery gears for your first off-road drive, but if you have a shovel, flag and a radio (walkie talkie) then please carry it with you. Rest all the off-road gears and recovery tools will be shown to you once you attend the briefing and you can read more about them here: https://carnity.com/advice/offroad/most-comprehensive-list-of-off-road-gears-and-recovery-tools-r81
      OFF-ROAD DRIVE
      Always wear long sleeve and closed shoes (no sleepers) to avoid any injury or sun burn. Carry hat/cap/scarf, in case you need to spend long time under the sun. Carry plenty of water and soft drinks of our choice to keep you hydrated. Carry your camera mounts if you like to record the drive (no hand held). No carrying or consumption of any type of alcoholic drinks on the drive.
    • By Gaurav
      A big Shout-Out to all our offroad club members from across the globe 🌍
      Congratulations on reaching a new milestone of having over 50+ Nationalities Offroaders in Carnity Offroad Club. One of the very few off-road clubs in UAE that welcomes and appreciates multicultural members.
      At Carnity Offroad Club, we drive united as a truly multicultural family, bringing with us our thoughts, experiences and share interesting knowledge with our ever-expanding Carnity family. We pride ourselves at speaking different languages, having different views on our car knowledge and Off roading, but drive in Unity as it is the - way of life in true Dubai, UAE style.
      So come and join our Carnity Offroad Club and add your own special flavour to enhance UAE’s ever-popular Offroad experience.
      Below is the list of the various nationalities. In some nationalities even though there might be more within our group, we have mentioned only max 3 people. If we have missed out any nationality, please let us know and we shall update this list.
      50 and counting - as of July 2021
      Afghanistan: Ali Abbas Ali, Abu Muhammad  Argentina - Martin, Miguel Ibarbia Bangladesh - Jalil Belgium - Frederic, Vanessa8580 Brazil - Jorge Stepniak Felippe, Daniel Noguira, Canada - Adam Marston China - Zixuan Hang (Charlie)  Denmark - Soren, Frederik Bisbjerg Egypt - Melenany, Mark Sorial, Nabil Bishara El Salvador - Mario Cornejo  Finland - Matti Brockman, Tero Vallas France - Emmanuel, Frederic Demolder Germany - Ace1988 Greece - Stav Hungary - Tamas Hoffmann, Archibald Jurdi India - Srikumar, Asif Hussain, Gaurav,  Indonesia - Zed, IMAMP Iraq - Aus Alzubaidi Iran - Yousef Alimadadi Ireland - Barry Italy - Magellan, Ale Valecchi, Lorenzo Candelpergher, Luca Palanca Falsini, Enrico Biscaro Jordan - BIG T, G.Huz Lebanon - Edouard Malaysia - E.C Tan Mauritius - AnishS, Veedooshee,  Mexico - Javier M  Morocco - Jamy B Netherlands - Panda82, Xaf, Jeepie, Mels Wolf,  New Zealand - Warren Flay Pakistan - Rahimdad, Bilal Ahmad, Atif Palestine - Mohamed Seidam The Philippines - Jun Zamora, Rinelle Sanaani, Kaile Barrameda Poland - Szymon Stankiewicz, Piotr Kolodziej Romania - Arman Russia - Mikhail Lukichev Scotland - Foxtrot Oscar Serbia - Marko Todorovic, Predrag Acimovic Singapore - Jerry Han Spain - Vsmano, Nacho, Jose Martin, Sri Lanka - Rizwanm2, Athula and Yasas South Africa - Gawie Herholdt, Colin Jordan, Hennie Schoeman, Jeandre Bezuidenhout, Kalahari  Sweden - Per A, M.K, Christian Andras  Switzerland - dberclaz Syria - Noor, Basil Turkey - Sertac, Halit Mert Issever, Denizzalbayrak, Mehmet Volga Ukraine - YevgeniyDYM United Kingdom - Richard Melish, LewisCocks90, Wrangled United States of America - Jeffrey Osito Pilgreen United Arab Emirates - Shehab Alawadhi Venezuela - Alexander Alcala
    • By Naveen Raj
      Hi @Gaurav Sonii understand from Fred that you are driving a tuned Pajero, I am driving 2008 3.0LWB which has the transmission upshift issue. I am planning to do ecu remap from chipcentic, so prior to getting this done, thought of getting feedback from you on the engine performance and any other issues confronted post upgrade.
