COVID 19 Compliant - Morning Fewbie Plus Desert Drive - Lisaili - Dubai - 23 Oct 2020
dune jockey
This drive is organized in full compliance with the COVID19 guidelines. We expect every member that joins this drive to go through below information and strictly follow these guidelines in order not to jeopardize someone's health, and to ensure we can keep organizing these drives safely.
MUST READ AND TOTALLY AGREE: COVID19 Precautions
MUST READ AND TOTALLY AGREE: BAN POST
Two Way Radio Guidelines
  • Every Off-roader brings his own radio, programmed to the frequencies described in below advice topic.
  • We will not share spare radios or program your radio on the drive. If you need assistance in programming the radio, post a topic on the Carnity website with your questions and we will help you out.
  • No radio = No drive. It is an essential tool and you should make sure you bring it on every drive and learn/practice how to use it.
Drive Details
Level:  Fewbie plus and Above (Fewbie members signing up need to have completed at least 5 Fewbie drives).
When:  23 October 2020, Friday
Meeting time: 6:00 AM (SHARP - Without any exceptions)
Action Plan:  We will drive from Lisaili to Faqa which has a nice mix of Technical , medium to long range dunes and some really tricky areas. Offroading skills will be tested to the core
Meeting Point: https://goo.gl/maps/WmnzTjeVRo5vJyxt9
Approximate finish time: 10:00 AM
THIS IS A COMPRESSOR ONLY DRIVE. WE WILL STARTING AND ENDING THE DRIVE AT THE SAME POINT, WHICH IS NOT CLOSE TO AN AIR LINE. IF YOU DO NOT HAVE A COMPRESSOR, PLEASE DO NOT SIGN UP FOR THIS DRIVE. IF YOU ARRIVE AND HAVE NO COMPRESSOR YOU WILL NOT BE ALLOWED TO JOIN THE DRIVE.
LIMITED SPOTS AVAILABLE:
  • Limited to 10 Fewbie and above drivers. RSVP will close on Thursday - 9 AM.
  • Restricted to Fewbie with 5 or more drives at Fewbie level. If you have not done the required number at fewbie level then do not RSVP on this drive
PLEASE RSVP ON THE BELOW CALENDAR
@Chaitanya Dcan you please remove me from the drive. I choose the wrong drive..I already joined your evening drive same day.. thank you
Thanks and appreciate your quick response. Hope you enjoy the other drive
2 hours ago, Gregory Perkin said:
First reserve please for the waiting list!
Added you to the drive as you requested first. I wonder if you RSVP on any other drives?
Waitlist as of now, will let you know if anyone opts out
1. Salarios
2. Rizwanm2
Edited by Chaitanya D
Many thanks. No I'm not RSVP for any other drive (missed it by 10 seconds). See you at the weekend
12 hours ago, Salarios said:
Hello boys and girls! I'm back in Dubai on Wednesday, and would love to join you guys on this drive, in case anyone drops out. :)
welcome back to Dubai.
