When every second matters: 4in1 inflation/deflation kit and Apex-like precision deflating valves
1 hour ago, PaoloMaraziti said:
So, summarizing the best setup you’d suggest is
1. apex valves for deflation (don’t have )
2. twin ARB compressor , maybe with the digital pressure gauge (I have a twin portable now with tank)
2. I am lost about the hoses and all-wheels-at-once … clarification pls !
Hi, the 4 in 1 refers to the ability to deflate or inflate four tires at once, there are several brands available or it is possible to make one yourself with parts from amazon, a picture will explain it better, but 4 tire valves and a central hub to allow air into all 4 at the same time or out at the same time. the device connects directly to your compressor, this is where a powerful compressor is important as it will be working continuously for a longer time. You need to have a 100pc duty compressor such as the ARB mentioned a lot in this post for this work effectively. Duty refers to the amount of time the compressor can run without overheating and cutting off.
13 minutes ago, Lorenzo Candelpergher said:
So, after some thinking, investigation with @Carnity members and reading through this thread, I got my Apex Valves and I must say they are incredibly fast.
The engineer in me, however, never rests, so the first thing I did was a proper before / after time comparison with the aid of my professional stopwatch operator, my son Miki, to see how serious were the multiple claims I had read.
Here it is..
Test on Apex Valves done on single BFGoodrich 255/75R17 A/T KM2 tire:
Deflation time
(from 35psi to 9psi including fine pressure tuning and cap removal / reinstatement)
- normal valve: 90"
- Apex valve: 30"
Result: Apex 200% faster
Inflation time
(from 9 psi to 35psi including cap removal/reinstatement and pressure fine tuning)
- normal valve: 95"
- Apex valve: 70"
Result: Apex 35% faster
Conclusions:
(i.e. how to justify my next mod to my wife):
I will sleep 4 more minutes before every morning drive and get home 1'40" earlier after every drive. Considering I do approx. 100 drives per year, assuming a lifespan of these valves of at least 2 years, I'll be saving in total almost 10h/year, at a cost of 35 AED/h ..
That is, of course, unless I get wider tires, which would increase the above benefits proportionally.. 😂😂😂
I didn't know what to say @Lorenzo Candelpergherexcept 🤣🤣🤣🤣🤣🤣🤣 and congratulations
2 minutes ago, PaoloMaraziti said:
Hi @Hisham Masaad, how your piping works ? e.g. I understand that you have valves closer to each tyre so to run short hoses ?
Yes @Paolo Pellegriniconnections are made to each tire. With a small hose I connect to the tire. Through the mobile App you put the target pressure. Till target pressure reach, the app will give an alarm...... and that's it😊
  • WOW (+2) 1
16 minutes ago, PaoloMaraziti said:
no worries and many thanks @Hisham Masaad, it looks like a great idea. Net ARB compressor and pressure control system app, piping, 4 short hoses .... and maybe a fridge to sip the cold beverage inside the cool car while the system does its job ! :)
yes, to be honest this is my next project. A fridge. The problem I am not finding small fridge to set between the seats. 🥲
@Hisham Masaad @PaoloMaraziti I purchased a Dometic Fridge that I have set in the middle seat at the back.  It’s easily accessible from the front however I do have disproportionally long arms?
It’s designed to be held down by the seat belt and stays nicely in place having driven with it for 4 drives now.   It doesn’t cool heavily and my experince is endure the drinks are already cold … then the fridge works great keeping it that way! (Maintains -20 vs interior temp)
I have seen online someone install a Prada Centre console fridge but I felt it looked too large and may get in the way when driving (elbows).
Edited by Niki
Many thanks @Nikifor the advise. Yes, Ive seen it in ACE, keeping it as an option, till I check others. Today I saw ARB posting on instagram as well, which I am planning to visit them today 👍🏽
Anybody got issues with APEX valves and TPMS ?
I am going install them but my current TPMS is attached to the old valves, so it won’t work anymore (used only to trigger a low pressure warning light on the dashboard)
I have a FJ Cruiser
It will work. The TPMS sensor is removed from the stock valves and connected to the Apex ones.
