Srikumar
COVID 19 Compliant - Morning Newbie Desert Drive - Mahafiz - Sharjah - 29 May 2020
Welcome to the COVID 19 "new normal" lifestyle with restrictions and precautions for everyone safety.
Moving forward and respecting authorities guidance all desert drives will be done under strict control.
No Gathering | No Briefing | No BBQ | No Eating Together | No Touching | No Hugging
MUST READ: Not following these rules and precautions = Not allowed to drive.
We are only allowed to drive through the desert, as we are driving on the road now. So we will only do the desert driving just by sitting inside our cars at all the times and leave the drive without socializing or coming close to each other.
Just like before we like to continue our desert drives through out the year, but this time we need your immense support to understand the strict control and to help everyone follow them all the time.
For members who are fasting, they can break their fast discreetly and convoy will be stopped during that time and until they offer their prayer.
How to maintain "STRICT" Social Distancing
  • Meeting point will be set slightly (100m - 200m)  inside the desert track.
  • So, that you individually deflate your tires on the tarmac before reaching the meeting point.
    • While deflating tires, stop cars 10 meters away from any other car.
  • Drive signup on calendar will be closed on Thursday morning by 9 AM.
  • Convoy numbering and briefing will be posted here on this drive post before 6 PM on Thursday.
  • All participants need to read & acknowledge the briefing by clicking "Totally Agree" reaction image.png
  • Switch on your radio when you reach the meeting point on the set frequency advised by the trip lead in the critical briefing here.
  • Once everyone reach to the meeting point, everyone stay inside the car at all the times.
    • Trip lead will do the roll call, convoy numbering recap, critical briefing over the radio.
    • Any suggestions or issues will be discussed over the radio too.
    • You can also speak to other members through the radio only.
    • So please make sure that your radio battery is fully charged.
  • Once all set, trip lead will start the drive as before.
Refusal and Recoveries with Social Distancing
  • Every drive will have 1 lead Marshal and 1 or 2 supporting senior members/crew.
  • Whenever there is a stuck or refusal, only Marshal / Senior Member / Crew is allowed to handle the situation.
  • Everyone else including the stuck car driver, stay inside the car - AT ALL TIMES.
  • Marshal / Senior Member / Crew is only allowed to step out to access the situation and do the recoveries:
    • They will wear mask and gloves at all times when they are outside their car.
    • They will try to help self recover through the radio guidance.
    • If not they will use required recovery gear and do the needful (shovel, tug or winch, as required).
    • If at any time Marshal require help, then only you are allowed to step out by wearing face mask and gloves at all times.
Drive completion and inflation
  • Now, there will not be any gathering or sitting down together for food-break like before.
  • Once drive is finished, after reaching the tarmac, everyone is requested to move away 50-100 meters before starting their inflation.
  • For drivers having no compressor, can head to the near by fuel station.
  • If drive is ending at a place where there is no fuel station near by, then trip lead will inform in advance so that drivers having their own compressor can join only.
  • Now Strictly no more sharing of compressors, radio, shovel or any recovery gear, at any times.
Mandatory things you require to attend the drive
  • Face mask - at least TWO face mask is needed in case one get damage or fly away.
  • Disposable rubber gloves - at least two sets are needed.
  • Wear face mask and gloves at all the times, when you are out of your car.
  • Carry plenty of hand sanitizer and object sanitizer (spray).
    • Use your sanitizers generously, whenever you step out to help or recover.
    • Sanitize your hands before getting back into your car.
    • Sanitize your recovery gears, if you have used them.
  • Fully charged radio - without any excuse - No radio = No drive.
  • Shovel - Must for every car, to do little self recovery
  • Safety flag - Must for every car, like before
  • Compressor - If joining the drives that is ending far from the fuel station.
Mandatory precaution that you need to take at all times
  • Do not step out of your car UNLESS/OTHERWISE advice by Marshal / Senior Member / Crew.
  • No shaking hands, hugs or touching each other.
  • No sharing of food, drinks or recovery tools.
  • If you are not feeling well, please stay at home and take a lot of rest.
  • If you have travel in last 14 days, then please do not attend this drive.
  • If you feel unwell during the drive, please let trip lead know so he can plan an early exit.
  • Not more than 3 pax in a car and if all 3 aren't living together, then they should wear the mask inside the car too.
Drive Details
Level:  Newbie and above - NO ABSOLUTE NEWBIE ALLOWED.
When: 29 May 2020, Friday.
Meeting time: 7:00 AM (SHARP - Without any exceptions)
Action Plan: Morning drive till about 10:30 AM
Meeting Point: Mahafiz -  https://goo.gl/maps/n9Hfccra6uQaaGqh9
Approximate finish time: 10:30 AM
End Point: ADNOC Station - https://goo.gl/maps/hGg82AoRqUjn73WA8
LIMITED SPOTS AVAILABLE:
  • Limited to 12 cars only. RSVP will close on Thursday - 9 AM.
    • 1 Lead Marshal + 2 or 1 Senior Members + 9 or 10 Members.
    • If the RSVP is full and you wish to join, please mention your name on the drive thread to add on the waiting list
PLEASE RSVP ON THE CALENDAR
  • Totally Agree 8
Hi @Nacho, since you are on this drive I will bring your rope set along with me. I thought you were travelling, hope not out of Dubai as you need to quarantine yourself if you travel abroad.
Hi @Rahimdad! I was only travelling for this last long weekend, and only to Fujairah! Perfect for the rope! I will bring the money with me. (by the way, i sent you a whatsapp, not sure if you've received it).
Thanks!
Must watch before the drive
  • Totally Agree 3
  • Well Done 3
Hi - I see all drives have reached their limit. Pls let me know if anyone drops out or a space becomes available. I can do Newbie/Fewbie morning or evening. Hope all is well. - thanks. Ali (BUNTY_and_POPS)
Radio Frequency will be   Carnity Channel 1: 446.00625 MHz.
Please make sure to bring your two way radio and have it set to this frequency.
Convoy Numbering
1. Rahimdad - Pathfinder
2. Asifk - Pajero
3. Janarthan - Humnmer H3
4. Andy_macdxb - Pajero
5. Shiju Manuel - Pajero
6. Srikumar - XJ
7. Jose Martin - Pajero SWB
8. Szymon - Montero
9. Lorenzo - Patrol Y62
10. Mikhail - Prado
11. Sertac - JGC
12. Nacho - Wrangler
13. Wrangeld - TJ
  • Thanks 1
  • Totally Agree 5
  • Well Done 1
Dear @Wrangeld and @Srikumar thank you very much for your help in fixing my pop-out. I particularly appreciated your extremely careful approach towards health & safety, constantly reminding not to take risks while the car was lifted, while digging under the wheel and while handling the tire during inflation. Of course thanks also to @Rahimdad for leading the convoy and taking us to the play area, which was indeed quite fun.
The view from fossil rock was beautiful (next time I'll take the drone!) and the descent indeed quite an interesting new experience in 4L 1st gear.
I'm attaching our route today. For those who fancy how I got it, I used Pathaway on my mobile. I find it pretty cool: total distance 17.7km, 3h 7min total ride time (including stops).
  • Like 3
  • Well Done 5
First Carnity drive for me today. Really enjoyed it, thanks to all veteran drivers for their expertise and guidance. Currently removing back bumper from Paj. Fun!
  • Like 5
Indeed, it was a great drive. I really enjoyed it. I will try to join upcoming newbie drive with my own vehicle. I have been learning a lot as copilot, but the feel behind the wheels is awesome. I would like to thank everyone on this group.
  • Like 5
  • Similar Content
    • By Srikumar
      This drive is organized in full compliance with the COVID19 guidelines. We expect every member that joins this drive to go through below information and and strictly follow these guidelines in order not to jeopardize someone's health, and to ensure we can keep organizing these drives safely.
      MUST READ AND TOTALLY AGREE: COVID19 Precautions
      MUST READ AND TOTALLY AGREE: BAN POST
      Two Way Radio Guidelines
      Every Offroader brings his own radio, programmed to the frequencies described in below advice topic. We will not share spare radios or program your radio on the drive. If you need assistance in programming the radio, post a topic on the Carnity website with your questions and we will help you out.  Make sure your radio is fully charged. It will be your only way of communication while driving. Before buying, please carefully read below advice so you are informed properly on which model / cost / shops... No radio = No drive. It is an essential tool and you should make sure you bring it on every drive and learn/practice how to use it.
      MUST WATCH: NEWBIE VIDEO BRIEFING
        Drive Details
      Level:  Newbie, Absolute Newbie and Above (All Levels)
      When:  July 10 2020, Friday.
      Meeting time: 5:00 AM (SHARP - Without any exceptions)
      Meeting Point: 2nd Dec Cafeteria - https://goo.gl/maps/MxnMF2fHeGnKZ4vf7
      Approximate finish time: 09:00 AM
      End Point: Tawi Nazwa Farm - https://goo.gl/maps/LjPWf8DebrAuNSWg9
      Limited to 15 cars only. RSVP will close on Thursday - 9 AM. 1 Lead Marshal + 2 Senior Members + 12 Members. If the RSVP is full and you wish to join, please mention your name on the drive thread to add on the waiting list.  Latecomers will be returned back - without ANY EXCEPTIONS. Members without RSVP will be returned back - without ANY EXCEPTIONS. Please withdraw your RSVP, if you aren't joining, so your spot can be taken by others. Repeated no-show members after RSVP will have their account suspended for a month.
    • By Frederic
      MUST READ:
      MUST WATCH: OUR NEWBIE VIDEO BRIEFING:
        Drive Details
      When:  July 3 2020, Friday.
      Meeting Point: Mahafiz Trees  - https://goo.gl/maps/NMjLvYCrSzHjYUaH9
      Approximate finish time: 8:30-9 AM
      End Point: Adnoc Station Tayba - https://goo.gl/maps/kGpjJyQCWp9fkUbk9
      P.S. Tyres can be inflated at the Adnoc Station in case you do not have a compressor.
      PLEASE RSVP ON THE BELOW CALENDAR
    • By Gaurav
      This drive is organized in full compliance with the COVID19 guidelines. We expect every member that joins this drive to respect and follow these guidelines strictly in order to not jeopardize someone's health and to ensure we can keep organizing these drives safely.
      Meeting point will be set slightly (100m - 200m)  inside the desert track. You individually deflate your tires on the tarmac before reaching the meeting point. While deflating tires, stop cars 10 meters away from any other car. Drive signup on calendar will be closed on Thursday morning by 9 AM. Convoy numbering and briefing will be posted here on this drive post before 6 PM on Thursday. All participants need to read & acknowledge the briefing by clicking "Totally Agree" reaction. Switch on your radio when you reach the meeting point on the set frequency advised by the trip lead in the critical briefing here. Once everyone reaches to the meeting point, everyone stay inside the car at all the times. Trip lead will do the roll call, convoy numbering recap, critical briefing over the radio. Any suggestions or issues will be discussed over the radio too. You can also speak to other members through the radio only. So please make sure that your radio battery is fully charged. Once all set, trip lead will start the drive as before.
      Every drive will have 1 lead Marshal and 1 or 2 supporting senior members/crew. Whenever there is a stuck or refusal, only a Marshal / Senior Member / Crew is allowed to handle the situation. Everyone else including the stuck car driver, stay inside the car - AT ALL TIMES. Marshal / Senior Member / Crew is only allowed to step out to access the situation and do the recoveries: They will wear mask and gloves at all times when they are outside their car. They will try to help self recover through the radio guidance. If not they will use required recovery gear and do the needful (shovel, tug or winch, as required). If at any time Marshal require help, then only you are allowed to step out by wearing face mask and gloves at all times.
      There will not be any gathering or sitting down together for food-break like before. Once drive is finished, after reaching the tarmac, everyone is requested to move away 10-20 meters before starting their inflation. For drivers having no compressor, can head to the near by fuel station. If drive is ending at a place where there is no fuel station near by, then trip lead will inform in advance so that drivers having their own compressor can join only. Strictly no sharing of compressors, radio, shovel or any recovery gear, at any times.
      Face mask - at least TWO face mask is needed in case one get damage or fly away. Disposable rubber gloves - at least two sets are needed. Wear face mask and gloves at all the times, when you are out of your car. Carry plenty of hand sanitizer and object sanitizer (spray). Use your sanitizers generously, whenever you step out to help or recover. Sanitize your hands before getting back into your car. Sanitize your recovery gears, if you have used them. Fully charged and programmed radio - without any excuse - No radio = No drive. Shovel - Must for every car, to do little self recovery Safety flag - Must for every car, like before Compressor - If joining the drives that is ending far from the fuel station.
      Do not step out of your car UNLESS/OTHERWISE advised by Marshal / Senior Member / Crew. No shaking hands, hugs or touching each other. No sharing of food, drinks or recovery tools. If you are not feeling well, please stay at home and take a lot of rest. If you have travel in last 14 days, then please do not attend this drive. If you feel unwell during the drive, please let trip lead know so he can plan an early exit. Not more than 3 pax in a car and if all 3 aren't living together, then they should wear the mask inside the car too.
      Drive Details
      When:  July 03 2020, Friday.
      Meeting time: 5:00 PM (SHARP - Without any exceptions)
      Meeting Point: Tawi Nazwa Farm - https://goo.gl/maps/LjPWf8DebrAuNSWg9
      Approximate finish time: 09:00 PM
      End Point: 2nd Dec Cafeteria - https://goo.gl/maps/MxnMF2fHeGnKZ4vf7
