Gaurav Posted November 17, 2021 Author Share Posted November 17, 2021 23 hours ago, Lorenzo Candelpergher said: Some RFIs to the @Carnity Organizers: 1. Can you confirm that ALL Team members are required to record the track or just the lead? If all, we need to make sure all drivers are conversant with GPS tools, including the Fewbie Member. Yes please, all team members need to record the complete GPS track. 23 hours ago, Lorenzo Candelpergher said: 2. Can you qualify what is meant by "tampering with GPS"? What happens if one of the team members fails to record the track, accidentally stops recording or drains the phone battery or has a phone overheating issue? Are all individual team member tracks going to be handed to the Organizers at the end of the drive? Tampering means, transferring tracks from one device to other, OR editing, merging, splitting the actual event track is completely prohibited. As GPS tracking is the only means to verify so we request all teams for their full compliance, please. This event is not a carnity regular drive and an event to identify "CHAMPIONS" so we expect a champion-like performance without any negligence, excuses, or accidents. Mobile battery drain is usually for lead, so others can start recording and switch the screen off and keep verifying after every few minutes. Yes, all individual GPS tracks of the winning team will be properly verified without any compromise or leniency. 23 hours ago, Lorenzo Candelpergher said: 3. Can you confirm that ALL Team members required to drive a circle around the waypoints or just the lead? This is to plan drive execution accordingly. Yes please, we need to see the circle on the GPS track to verify that each individual has been to the same waypoint. The variance of 5-10 meters is acceptable factoring the GPS, devices anomalies, but not 50 meters. 23 hours ago, Lorenzo Candelpergher said: 4. There is a starting point from where 5 waypoints are to be reached in whatever order, if I got it right. I'm not clear about the conclusion of the drive: are we done when we reach the last of the 5 waypoints (regardless which one it is as per our route and regardless of the exit point) or do we have to head back to the starting point or any other designated exit point? Yes, you can cover all 5 waypoints however you wish to target. After completing all 5 waypoints every team needs to return to the starting point. Basically, Start and Finish points are the same. 4 1 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
Gaurav Posted November 17, 2021 Author Share Posted November 17, 2021 17 hours ago, Ruan van den Heever said: What are the rules in the event of a complete mechanical failure of one team member's car? Is the team disqualified? Can that member continue with another team member? As mentioned in the beginning. Due to any mechanical failure, breakdown or accident, the trip lead needs to inform any of the crew immediately. We will mobilize the support team asap with the shortest, fastest track we have marked on this entire area. Once the support team arrives and verifies the genuineness of the breakdown, then the rest of the team can start to continue the remaining track. I expect the support team should reach within 15-30 minutes (most likely) but we still mentioned 15 mins - 2 hours, so that this cannot be used as a loop-hole to get rid of the weakest link. 4 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
Popular Post Gaurav Posted November 17, 2021 Author Popular Post Share Posted November 17, 2021 @Daniel Rodas @Werno @Javier Lucero @Zed @Alexander Alcala @Mario Cornejo @M.Seidam @Humayun Ghias @varunmehndiratta @Hisham Masaad @Anoop Nair @Niki @JamesThorn @Ruan van den Heever @Chaitanya D @Foxtrot Oscar @Lorenzo Candelpergher @Tbone @Jeepie @sertac @Asif Hussain @Kailas @JeromeFJ @Bernard Kalaani @Looper @Alexanderrr @Mus_hus78 @Daniel Yang @Wrangeld @GauravSoni @Matt.T @Warren Flay @Ale Vallecchi @Mohamad Anwer @Frederic @Srikumar @Jorge Stepniak Felippe @Rizwanm2 Desert Champions Trophy - Final action plan Meeting time: 06:00 AM (SHARP - Without any exceptions) Meeting Point: https://goo.gl/maps/SCJYQgPb6VH2iSqq6 Arrive and deflate Place vehicle stickers Three stickers for each car Two on rear side glass window (left and right) One on backglass screen on the passenger side (top) Starting Point: To be sent to trip lead at 6:00 AM, 19 Nov 2021. Convoy ordering: Once you arrive at the starting point, line up cars as per your team numbers. Car recording: All car photos and videos will be taken from all sides to verify any damage. Waypoints distribution: Each team will have 30 minutes from receiving the waypoints to start their drive. All waypoints will be given in printed sheets and through WhatsApp to the trip lead only. Radio: Channel 1 will be used for all event coordination. Each team can choose use their channel number and announce. Time Record: Once the team crosses through the two tall flags their time starts and when the whole team returns through the same tall flags, their timing stops. Whichever team completes in the shortest amount of time, will win. Waypoints approach: There will be 5 waypoints that each team and team member needs to visit and make a circle to mark on the GPS track. Any break in the track of any member log will disqualify the whole team. 5-10 meter variance is acceptable for factoring in the GPS and devices anomalies. After completing those 5 waypoints, each team needs to return to the starting point and pass through the same tall flags to stop their timer. Time lag: Each team will leave after 5 minutes of the gap to avoid crowding on the first waypoints. Location sharing: Each team lead needs to share the WhatsApp live location for 8 hours, so we can monitor the progress for safety and verification purposes. The team lead can appoint another team member to share the live location for saving the battery or device usage. Support team and Backup leads: Two sets of backup leads (4 cars) will be positioned on two different waypoints. Reporting breakdown: Any car breakdown, mechanical failure or accident need to be reported to any crew immediately, so that we can mobilize the nearest support. Gaurav - 050 5258706 Srikumar - 055 9567471 Frederic - 056 5042632 Refreshments: Breakfast and beverages will be served after each team returns. P.S. Bring your camping chairs, umbrellas, canopy (if you have) as you might have to wait until all team finishes. 11 3 5 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
M.Seidam Posted November 18, 2021 Share Posted November 18, 2021 8 hours ago, Gaurav said: Tampering means, transferring tracks from one device to other, OR editing, merging, splitting the actual event track is completely prohibited. Definitely understand. Only one question to clarify . Will additional phone or device recording in the same time ( and kept in cool box for example ) is not considering any one of the above mentioned? This is realy important Gaurav as there is no place for me to tolerate on my self to disqualify my team just because battery went off or phone overheating issue . Thanks 🙏 3 Link to comment Share on other sites More sharing options...
Ale Vallecchi Posted November 18, 2021 Share Posted November 18, 2021 7 hours ago, Gaurav said: Starting Point: To be sent to trip lead at 6:00 AM, 19 Nov 2021. Question 1 - Meeting and starting points being different, the line up as indicated (next to the flag poles) will not be necessary at the meeting point? 7 hours ago, Gaurav said: Radio: Channel 1 will be used for all event coordination. Each team can choose use their channel number and announce. Question 2 - can we indicate the team's chosen radio channel here? If yes, I'd like to pick channel 2. Thanks 3 Link to comment Share on other sites More sharing options...
GauravSoni Posted November 18, 2021 Share Posted November 18, 2021 30 minutes ago, M.Seidam said: Definitely understand. Only one question to clarify . Will additional phone or device recording in the same time ( and kept in cool box for example ) is not considering any one of the above mentioned? This is realy important Gaurav as there is no place for me to tolerate on my self to disqualify my team just because battery went off or phone overheating issue . Thanks 🙏 I feel like you @M.SeidamI suppose we can record our track on two separate devices in the same car… one out for navigation and other as backup recording kept in cool box!! That’s no tampering! @Gaurav@Frederic can please confirm! 4 Link to comment Share on other sites More sharing options...
M.Seidam Posted November 18, 2021 Share Posted November 18, 2021 (edited) Final count down now toward end game .. 30 drivers , 6 teams and one 🏆 … lets bounce and dance together .. only one team will keep the trophy but all of us will have breakfast 🤣 Edited November 18, 2021 by M.Seidam 1 2 Link to comment Share on other sites More sharing options...
Jeepie Posted November 18, 2021 Share Posted November 18, 2021 If we are allowed to pick a radio channel now, we would like to claim channel 10 1 1 2 Link to comment Share on other sites More sharing options...
Gaurav Posted November 18, 2021 Author Share Posted November 18, 2021 4 hours ago, M.Seidam said: Definitely understand. Only one question to clarify . Will additional phone or device recording in the same time ( and kept in cool box for example ) is not considering any one of the above mentioned? This is realy important Gaurav as there is no place for me to tolerate on my self to disqualify my team just because battery went off or phone overheating issue . Thanks 🙏 Spare phone is acceptable. 4 hours ago, Ale Vallecchi said: Question 1 - Meeting and starting points being different, the line up as indicated (next to the flag poles) will not be necessary at the meeting point? Correct, at meeting point all trip lead will receive vehicle stickers from @Tbone Stick those stickers and deflate and you will get the starting point location at 6 AM on every trip lead whatsapp. 4 hours ago, Ale Vallecchi said: Question 2 - can we indicate the team's chosen radio channel here? If yes, I'd like to pick channel 2. Thanks Yes please. Noted: Ale team - Radio Channel 2. 2 1 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
Gaurav Posted November 18, 2021 Author Share Posted November 18, 2021 3 hours ago, GauravSoni said: I feel like you @M.SeidamI suppose we can record our track on two separate devices in the same car… one out for navigation and other as backup recording kept in cool box!! That’s no tampering! @Gaurav@Frederic can please confirm! Correct, that's not tampering. As far as phone stays in the same car and doesn't hop on hop off during tricky terrain. But we trust our leads completely for this little loop-hole compliance. 12 minutes ago, Jeepie said: If we are allowed to pick a radio channel now, we would like to claim channel 10 Noted: Team Arabian Wolf - Ale - Radio Channel 2. Team Arabian Camel - Marjan - Radio Channel 10 3 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
